ISC Eiger Small Pulley
*Rope:* *<13 mm*
*Strength:* *36 kN
*Weight:* *90 g
Specifications
Swing-sided micro pulley - able to be easily installed mid-line. Constructed from high strength aluminum alloy and designed for 12 mm arborist rope. Stylish anodised finish. Minimum breaking strength a whopping 35 kN and only 74 mm high. Unbelievable strength for its size and weight (only 90 g). Each pulley is 100% inspected for quality. Useful additional pulley in the Hitch Climber system. Approved to BS EN 12278. Made in Wales by ISC.
What are the opinions of splicing directly onto the sides of this with one eye? Is it coolto girth hitch a webbing sling
directly as well? This would turn from a swing cheek pulley to a fixed version-has anyone tested it and k ow o the results?
Cheers
Not tried or tested it, my initial thoughts would be the bend radius on the pulley cheeks is a bit tight, and how about putting a thimble into the eye to minimise that and problems with chafing?
Cheers guys, I thought the thimble would be needed. It's to be part of a rope guide I've been asked to make omitting the cost of the art pulley. Might just have to wait fir the pinto pulley instead. Thanks for the info
