Good post.
A good point. Oak is historically an open grown lover! Exact right habitat....:thumbup1:
Decompaction...Id say it depends on the method. Terravent? No..it picks it up and slams it right back down again....this will only further compact the problem...:001_smile:
I don't know about the Terravent but my de-compaction machine [works on a similar principle to the Terravent] certainly doesn't slam the soil back down.
Mulch is all well and very good, but in certain scenarios its just not practical.
  • Replies 22
So the gas escapes slowly enough once injected into the soil, allowing the soil/clod to settle relatively gently..? This may be what Hama was saying but unfortunately ( and not like him ) he does n't go on to explain his theory as to those situations in which it is most effective (more effective than others? )
Tim
Tim
I use my machine to de-compact and fissure the soil in layers, starting at a few inches working down as far as 600mm, I have total control over the volume of air injected too, with the terravent you won't have control of the gas released, but you can still work in layers, I hope that helps...
