Looking for set of green teeth. Usual supplier (Liston Equipment) have none in stock and say it will be 14 days before they have any. Anybody know of another supplier that I can try.
Cheers,
robert.
Global Recycling of Newark (01636 594 364) sell 1100 copies @ £4.00 + vat.
Fairly sure they also sell genuine Green components.
  • 3 months later...
  • 2 years later...
I've used a variation on Sideleaner's link: just held the threaded shank of the greentooth in the chuck of a drill. While gently pressing the worn face of the tooth onto the revolving diamond wheel, I spun the tooth in the drill.
Due to the concave face of the tooth, it will sit against the d-wheel at the correct angle (as long as you're gentle!)
Bought the correct size diamond wheel (100mm x 4mm) from D K Holdings for £120 inc. VAT & delivery.
Put a damp cloth beneath the grinding wheel to trap as much dust as possible. Still wore a respirator though. Took about 5 to 10 min's per tooth to remove about 1.5mm from the face.
See pic's below: sharpened tooth and sharpening in progress.
