Breather hole on MS200T fuel tank - Donde Esta?
Albedo
Getting a bit of a vacuum in my fuel tank so difficulty getting lid off and associated running problems.
Just wondered if I should be able to see a breather hole in the lid or if it is elsewhere.
Gave the whole lot a good blow today with the air hose but should really know where to find this wee thing.
Any pointers appreciated.
Thanks Skyhuck.
Bit hard to miss once you know where to look. And theres me scouring the fuel cap for a little hole.
Me being me, I found said pipe and pulled the filter thingy on the end in half to see if I could blow it out from the inside. It hissed when I opened it. Inside is a diaphragm arrangement with little holes in, which all looked pretty clean.
I prized off the white plastic bit to reveal a little foam filter and there are the holes from the inside. All blown out and clean now.
Thanks again for the pointer, it was all quite clogged around the 7 little holes on the outside.:thumbup1:
By the way, this being an information exchange, i now know where my breather is, and you now know how to say 'where is it' in Spanish, ..... if you didn't already know that is:biggrin:
