What you need to do tom is eliminate wander lead or battery feed.
Its either one or the other
(suspect power lead connection or bad earth) First get a fully charged battery and connect it direct to the input side of the solonoid the try it with the wander lead, this should eliminate any power lead connection problems down the line or isolator switch problems.
(suspect wander lead or wander lead connection)If it still does it then disconnect the battery you've just put on and go back to standard connections and bridge the pins on the wander lead connection to bypass that.
(suspect solonoid) If it still does it the connect the battery to the output side of the solonoid and you bypass everything
Top stuff Dean. Thanks mate.:thumbup1:
