if its anything like the 039 where there is a lot of plastic covering the spikes, i used a dremel with a grinding wheel and just ground the plastic away to reveal more of the cutter, works so much better now with more than 3 times the dogs showing.
i have 66 dogs on my 441. they just bolt on in place of the old ones. if you go to your local stihl dealer they should be able to sort you out with some. they were about £12 I tinhk for the pair of them.
