hi
just droped the saw into the shop today as the chain brake return spring had gone and i thought they could stick a tacho on it and double check the tunning.
ill let you know what they find, until then iam gone dream about getting a nice new saw.
on that subject is there a saw that has the power and revs of a 361 but is a little lighter as i only have little arms and a bad shoulder, tried a 026 but is a bit slow imo
any thoughts ? could be sthil or husq!
cheers carlos
  • 1 month later...
My money would be on a blocked tank vent or low compression - compression falls as the saw gets hot and if it is borderline can stop a hot saw starting.
You can check a blocked tank vent by running the saw with a loose petrol cap.
Crank seals are unlikely as usually the saw races at idle and will need an over rich setting on the L screw to compensate - that is if it doesn't sieze in the early stages.
Spud
