Kind of hard to see.The brackets look to have a crusted and cracking top surface....Is that about right?
If so, I would say probably White Trunk rot (aka Phellinus igniarius)
Looks typical at the base to me. Typical strategy, emerging higher up the stem. It moves quite quick. Intense white rot of the stem. Often no signs from the canopy. (til later stages)
All the same, perhaps a second opinion would be helpful...?
edit...I m really not convinced it is Phellinus now I look again at those images mate! Sorry!
The top surface is crusted and cracked, the new growth has only recently started. There's a fair amount of dead smaller branches in the canopy, do you think I need to get a consultant to have a look, as it's near a building and at the top of a steep bank?
Polyporus squamosus - Dryads saddle as Giles said for the ones on Ash.
Dont agree with the ustulina though Giles.
I think the last shot on the Beech set show an older desicated bigger bracket.
Can't give an Id though.
I think the bottom one on the beech might not be Ustulina.:biggrin:
