FAO Hama, MonkeyD and other hippy treehuggy types
Andy Collins
OK I have this wonderful old Oak tree in a nicely sheltered position. Its still thriving though mucho decay lower down. What I'd like to do is ideally leave it to its own devices, to see its time out gracefully. However, it does have a minor target, ie new park fencing which isnt the cheapest to replace. What I'd like to know from you esteemed gentlemen, is what would recommend to hold the trunk together, or indeed would you bother? As far as tree surgery goes, I dont really wish to remove any growth, as I think it needs all the help it can get. Thoughts and opinions gladly welcomed.
  • Replies 28
If she is folding at the edges, she needs lightening, rods will help but, also increase stresses at certain points.
If you see a dip in one side of the cavity wall and a corresponding bulge as near as dam it opposite on the opossing wall she is failing by "hose pipe kinking" and the only real solution is to lighten her loads and give the walls a chance to thicken in keeping with the stress.
The body language of the formations should be the guide always.
She needs a the lowest crown as she can get with that trunk and she seems to have done that. As Tony said get the weight and balance right and she will stand for years. I would not bolt her Andy she looks like she is doing all the right things for herself:001_smile:
