hi,
Β
i've just been given a shaft off a stihl combi unit (used to have a chainsaw head)
Β
i'd like to fit a strimmer head to it.
Β
anyone know what models will fit i.e. fs 80, fs 55 ???????????
Β
failing that, anyone got a head to fit a fs400
Β
thanks
Β
dave
The shaft on the chainsaw attachment is much shorter than the strimmer attachment. About 18" shorter from memory.
Hi Dave
Β
To fit a head to your combi shaft you will need a gearbox and head complete and this may sound a bit weird but it is cheaper to by a Combi line head attachment (with shaft) than a head and gearbox on its own.
Β
Its because us dealers get a much better discount rate from Stihl on units than parts.
Β
Hope this helps.:001_smile:
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
