How many of you run chip boilers at home?
njc110381
  • Replies 31
With regards to linking a back boiler up to oil fired central heating. We had an old school plumber, flow & return to dhw, then 2nd flow & return linked to radiators. dhw gravity fed, upstairs radiators gravity fed then central heating pump fitted to bring hot water to downstairs radiators. If we switch the oil fired boiler on then the original thermastat will kick the oil in and out automatically if wood burner not hot enough.
