Hi guys,does anyone know if the fuel tank from a 020t will fit the 200t? Some little monkey ran over my 200t with the tracked chipper:sneaky2: and cracked the tank. I have 2 200t's and both have different part numbers on tank housing, will they both be slightly different? Cheers :thumbup1:
they fit but the whole tank vent breather set up is completely different... when i tried mating an 020 to a 200 it runs ok but the tank seems to need venting by un doing the fuel cap evan with the rero vent kit fitted ,but maybe mine is a completly different problem!
yes they do fit because i have done one but like he said the breather system is different you get a little breather pipe that you put on top of the tank but mine fell off but i had no problems with it breathing might be worth trying to clue the little pipe on because if i remember right if it falls off and it leaks a bit
Ok thanks guys i might give it a try cos i was qouted around £60 for a new one and the saw is a couple of yrs old at least
