Looking at getting a Carlton sp2010, Danequip 27sp or predator 450. Is there much difference in any of these or do any have known problems?
Looking at buying new and the Danequip is about a grand cheaper than the others. Advice please
If thats the carlton I think it is I.e semi driven I liked it but others dont, reqiures sensitive control and arbs ain tknown for that!:laugh1:
Best value for money pedestrian grinder for me is the little Rayco, goes in any where will grind out anything, but you need a bit of grunt to use it!:thumbup:
Just had a look at an rg20, very similar, Identical even to the carlton i was picturing in my head, I loved the carlton version of this, thought it was powerfull and well balanced.
i guess it depends on how much your going to use this and how tight a space you need to operate in on a daily basis, with the little rayco I can just about handball it in anywhere single handedly.
but this RG20 style would be a lot less work if using it more than 1 or two times a week and will probably prove worth the extra dollar
It wouldn't get a lot of use really, mostly domestic but would need to be able to handle big stumps and highways. I like the idea of self drive. I have used push alond type where one wheel locks on the hand break and it always felt like a battle. Always falling into the hole
yes these types require a certain (aggressive:blushing:) technique.
if you have the dough I wouldnt hessitate on the carlton version of that rayco rg20, good bit of kit and will still get into most back gardens, i think most gates are 28 inches wide worth checking against the carltons and raycos first, can be a pain if they dont fit.
Ive got the Predator 450 and its a beast. I have used to Calton and the Rayco and the 450 i find is better than both. This is due to the multitip that comes on them. If you have the money to spend then get one that self drives, i couldnt pull the rg20 onto my ifor with out someone helping me and it really is only good for little stumps as its a PITA the use in holes etc.
I have done some big old stumps with my 450 and it failry mullers through them, The biggest was a 7 foot wide holm oak stump, it wasnt as fast a big tracked grinder but 1.5 hours later it was done.
The greenmech is an identical copy of the 450 so the choice is yours!!!
Hope that helps!!!!
