hi
get on ok with mine feel its a good comfy harness although some of the above bad points raised i would have to agree with but have not been so bothered by them, id say if you could try a few different ones on would be the best bet.
carl
good job you diddnt have one of the early ones with the faulty stitching on the bridge mesterh, youd have crusified it even more!! mine had the bridge and shackel recall just in time-tineyst bit of shock loading and it would have failed
its an ok harness . . . as a spare
The bridge recall was because of a failure on the European Black and Red model not the Black and Green Safety Technology model. It was a PR move to replace all bridges.
I changed my bridge so long ago that I had forgotten about the ring cross loading the shackles. What a pain that was.
I am a gear junkie and I own a few lifetimes of saddles already and they are all so different when you get down to details.
I too would definately try as many as possible first. Or buy em all!
well mine was the blue and green model, i had it when it first came out as my boss at the time had links to the guy that designed or tested them, something like that. when we were informed about the bridge recall, when i checked my bridge by sliding back the sheath thing that covers the bridge from wear, (and easy visible inspection) the bridge webbing had seperated by approx 10mm, with just the stitching threads holding it together (just)
  • 1 year later...
mesterh youve hit the nail on the head very comfy but i think i would be happier spending more time cutting and less fiddling with the harness.
Oh and i have found it is brill for nipping the NADS! best thing is the back support that is one of the best ive had for that.
  • 6 years later...
