SO HERE'S THE QUESTION :confused1: are the larger swivels good for a main attachment point if vou want to plap two Krabs through it?:confused1:
cheers
Yes, you can fit a couple of Krabs to the swivel. I had one on my tree flex, but removed it as it twisted the lines too much when used with a VT.
  • Replies 53
Its so you can put your lanyard round a branch and attatch it to the small prussik so as not to side load the krab.
Comes in so handy doing that.I use a small 15cm sling and a couple of docking ring's just to keep in cinched in :thumbup1:
i use a 2.5 mtr yale xtc with a Knut knot on with pulley, works a treat, one of the best knots out there, never slips n holds reall tight!, dont climb with a long lanyard you dont need it and it just gets in the way!
hi ya i use a 2.5mtr yale xtc fire, with a knut knot n pulley, its a gr8 knot as it moves so gracefully yet tightens when and as needed without fail, keep to a short lanyard as you dont need a lenthy one it just gets in the bloody way!!!!
