Which Hand Winch.........
Mac McLennan
You know.......The tree that probrably don't need winching but you just want to be sure.
What do you use.
In that case i'd use a carters hitch which is easily set-up on a single pull line (does'nt work to well with 3 strand),
Or a compact fiddle block, I have 2 small isc double pulleys one with a becket, ready set-up on some 10mm rope its light and takes up little space.
got any pics?
got any pics?
The only pic I have, i'll have to look on the web for better tying instructions.
I tied the the old climbing line on the top of a Beech trunk just out of shot, which was right agaisnt a fence and between shrubs and stuff, so we had to bore cut it, and its closeness to the fence made wedging/levering it over a little tricky.
I've put a pulley in the system, you don't have to do that a biner will do or even feed the rope through the loop, the other part out of shot goes through another pulley attached to a tree then back through this pulley, so 2 pulleys in all for good advantage.
