I think this will be of little interest to most but I’m wondering - does anyone know about these old Walbro WJ carburettor’s….
I have this Partner 7000 pro saw, bit tatty but it’s all there and has frightening compression. It will pop with some fuel thrown down the intake so I headed to the carb to see what’s what.
Well, all looks surprisingly good, no fuel rot, no dirt in filter, diaphragm and pump all good blar, blar…. But the main jet check valve doesn’t work (surprise given general condition). And here’s where I ran into ‘issues’ - it seems like it was never supposed to work…. there is nothing in there that looks like it could act as a check valve. See picture of items that came out.
Edited by bmp01
Items 56 filter, 1 retaining ring, 23 plug are the same as mine ( I shouldn’t have removed the jet (LH part in my pic above) apparently 🙄
Item 20 check valve is an alternative fit part (that’s why it’s not highlighted).
Weird, a carb with the option of no check valve ??? 🤔🤔
I haven't got a proper hang of these check valves but the main jet venturi is only under higher pressure  than the diaphragm chamber when the throttle is shut and the downstream idle outlet is  subject to full manifold depression.
I still wonder  if blocking this would overcome the problem at the expense of idling??
I still have a strimmer with  the problem of air getting into the chamber via a leaky check valve to fix, along with a heap of other engines that need attention. Will probably have to wait till spring.
Sounds like you’ve got that bit sorted.
I was thinking I could wind in the hi speed screw…. that would block it. Engine ought to idle on the low speed circuit.
And buy the optional check valve 🙂
A brief update/summary for anyone visiting this thread in the future looking for a conclusion:
The saw now runs with the original parts pictured above. That is to say it does not have a check valve in the high speed circuit. It idles, accelerates, returns to idle totally predictably.
I did not expect this.
Hi speed circuit is not providing any fuel at idle - I can close the high speed screw completely with no change to engine.
And there is obvious no air going up the hi speed jet because the engine idles happily and forever.
I wonder if the wire gauze filter is behaving like a check valve once it’s coated in fuel…?
Dunno, but in this carb, with this saw there is no need for a ‘normal’ check valve in the hi speed circuit.
