So add yourself to the tip sites, that is a good start if you haven't already.
A couple of pointers:
Great, yes am sure we can all tip there.. if we know where here is...
We could of course give you a call... no we can't, email instead? err, cannot do that either....
But first off register as tip site.
Note that most established firms will have somewhere to get rid of their waste sorted, most likely those that use tip sites are away from their home area and want somewhere local to tip to save an hour or 2 round trip.. so you won't get a call every week.
Be flexible with what you can take. Split and dried logs tipped are never going to happen but 25kg lumps of wood are more likely if you can cut, split and dry them yourself (assuming this is for firewood)
Also try contacting local companies, if you want regular supplies then, as above, you need to become a good tip site for a local company and they are best contacted directly.  Some tips:
Logs are processed into sizes ready to burn once dry, these are not going to be free as that takes work.  If you are a going to be a tip site you need to be asking for wood not logs (arb arisings is the term used here).
As above be flexible.  Despite what the internet will tell you all wood burns(!) and releases the same amount of energy per unit weight when dry (when using a wood burner).  Less dense wood does take more space but generally that is not so much of an issue (also soft wood generally dries quicker, which can be handy).  In fact some softwoods are really good wood to burn once you figure out how to best split them (leave the faster burning woods in bigger chunks).
