Just acquired roughly 5 acres of land of which 0.5 acres in mowed but undulating lawn. The rest is very scrubby, again undulating but no major slopes with areas prone to getting wet. I'm planning to maintain the lawn for family use but preserve as much of the wild areas as possible by mowing paths into the scrub to enable us to walk the area.
I have a maximum budget of £5k to get what I need to manage it myself and I've done a lot of research online but looking for some experienced advice and reviews to guide me.  Thought I'd narrowed it down to a Grillo Climber 7.15 brushcutter but then read about issues related to poor quality generally with cost of spares extortionate.
Any recommendations very welcome, thanks in advance.
From a personal point of view and 33 years of looking after similar terrain as you indicated, my opinion is any choice of a "one machine for all jobs" can result in a poor compromise of all rather than excelling at any or every  task.
I found it much better to have a small light but powerful enough machine and have the ability to choose the implement to attach as the job/terrain/conditions  dictate.
there isn't going to be much about for that budget but with a bit of searching it should be possible to find a flail, a mower and a small garden tractor, kubota, iseki, etc. other uses can be found for a small tractor too, pulling a trailer, a sprayer can be attached, many implements can be ran from the pto, or from hydraulics.
Again I something similar, I use a quad bike and a flail mower, the advantage being the quad bike has other uses about the place, trailer towing, dragging etc.
I'm in a similar situation, though only about 2 acres in total. I ended up with an ancient Yanmar YM1600 tractor and a topper - does a good job keeping the paddock under control and will cut most things (long grass, scrub, bracken higher than the tractor) if you don't try to go too fast. It doesn't leave a neat, lawn like finish though. (Might do if I cut more regularly, but probably not even then). I have a Honda petrol mower to cut and collect the lawn. Tractor also carries things, tows things, harrows things... (Harrowing helps keep grass healthy). And it could do more - log splitters, little digger attachments etc.
The only issues with the tractor are that it's quite brutal, tricky to maneouvre in confined spaces and is a bit hairy on steep slopes, which I have lots of. The front wheels came off the ground once as I was carrying a load of logs up a narrow slope, and I had to eject - that was scary, and I was lucky. I now unlatch the rear wheel breaks and use them to steer in this situation.
If you get a tractor I'd suggest a more modern one with roll cage.
