...and on the attachment point, I have never found blades as robust as a heavy duty string setup.  Eventually you hit something and they are easily knocked out of alignment and you have to replace parts. I've been using 3mm Diamond edge string and a Oregon Jet fit head for  three years now and its amazing.  It will munch through anything. Granted I appreciate a blade can be useful to increase what a small powered machine can achieve, occasional use only.
Edited by Muddy42
Agreed . I use the same but 4 mm Diamond edge square on thick vegetation .
7 hours ago, Stere said:
Kombis do not  have bike handles, the loop handles are just not as good ergonomically
WWW.STIHL.CO.UK
For professional applications requiring high performance ✓ Order the 1.4 kW KM 131 R Petrol KombiEngine here!
131R loop handles, 131 bike handles.  My son loves bike handle machines, I hate them.
I had to smile when I watched some trainees with bike handle machines fitted with mulching blades in some briars. As you know, the best results with these blades is a vertical movement, and watching these lads bobbing up and down like weebles was hilarious, I thought.
My loop handle machine would have only required me to move my arms, not my whole body. Also, use of hedge trimmer attachments with bike handles is not recommended at all.
5 hours ago, Peter 1955 said:
WWW.STIHL.CO.UK
Never used a long reach trimmer but why are bicycle handles unsuitable
WWW.STIHL.CO.UK
It would be for cutting v v  heavy grass mixed with briar along electric fence I want it for.
What tool would you use for such a job
I find regular hedge trimmer quiet good for the job good bit of effort dragging it through the heavy grass and my back doesn't like it thought a long reach trimmer or powerful brush cutter might be easier?
I don't need to mulch just cut and leave it
Edited by aidank
Well, given those parameters,
WWW.AMAZON.CO.UK
Free delivery and returns on all eligible orders. Shop Oregon Universal 3 Tooth Brush Cutter Blade 3.0 x 255mm for Grass and Vegetation in Gardens, Professional and Heavy Duty, Fits...
Unless you've bought a bigger machine than a Kombi, beware the 300mm blade. It's a millimetre thicker, far heavier, and probably too big for a Kombi. I bought one, and it takes too long to spool up, and too long to slow down. I'd expect concerted heavy use to damage the drive line. If you're meeting a post every few metres, loop handle all the way, for precision.
Basically, as far as I understand, it's because you don't have the same control over the machine. Just imagine trying to cut the hedge face vertically with a bike handle strimmer. The idea doesn't appeal to me.
