carefully as on any engine!!
No idea but do expect timing marks on the crank flywheel and any pulleys on the cam/cams.
You probably need to make sure the engine is set on TDC when doing it....hopefully pretty standard, good luck.
Check the valves haven't contacted the piston crowns when the belt failed.
  • Thanks 2
Thanks, got crank mark, but cam pulleys just have hole you put pins in but can't find holes on crankcase. Have looked it up since post and found a bit more out, number on pulley has to be at top and holes horizontal, will use a couple of drill bits to see if the lock in some way.
Valve are non interference
Update, got it back together put a set of jump leads on it turned it over with plug leads off to get a bit of oil up and about, put some fuel in it and replaced plug leads pulled choke out turned key after a couple of turns away it went. Not bad considering that engine has sat for just over 5 years and local dealer said parts were obsolete, but just on the off chance looking on ebay found an oil pump and got a timing belt from bearings place. So rather then a pile of scrap I got an engine.
