Hi I'm having real problems with my timberpro 6150 chainsaw, it seems that it will.run then cut out, if I remove the fuel cap then put it back on it will run for a minute. Does the tank have a vent that could be blocked and if so where would it be? Can I get a vented cap to fit it? Looks like a standard screw cap? Cheers its doing my head it
You are on it matey . Classic blocked tank vent symptom .  You will find it somewhere on the upper surface of the tank .
Can't find it anywhere😟😟😟
Remove the airfilter and you should see the fuel pipes which go into a single grommet, the breather is separate  typically a white Echo type pushed into a black grommet  on top of the tank by the carb
Hi nothing there, can't see no vent
