As we look at building the new website - it'll be more limited in chains we offer as although it's great to have a good range it can be bewildering and keeping stock is hard work... the Panther chains have generally gone down well but we have x4 variations where we should really only have one so in future the below chains (other than 1 or 2) we won't keep stocking because:
  • Mainly folks like the non safety or unguarded chains
  • The P+ chains with top plate marking see to have worked well so we'll only do these in future (apart from in 1/4 .043[1.1mm] and .325 .043[1.1mm] as these are too small to make the process viable)
So the below chains we need to clear out - will do for 50% off as long as you have a few - 60% off if you have a lot whatsapp me on 07752145001 if need more info - ideal if you can work out what you may like to buy from the part number - number of drive links a chain has is at the end of each SKU. Yes a little bit a daunting list 😬
I can't seem to copy and paste it on here so that it appears correctly..
Excess Chain List CSB June 2024.docx
