32 minutes ago, Brushcutter said:
Trilo do a similar thing. They a massive one for mowing runways and airports. I've only seen the sucky for leaves on golf courses but Enfield council have one that mows as well.
Used a trilo mower vac before for sucking the clippings off turfgrass before lifting it for instant lawns, not a big one. 60 hp tractor was well able for it. Well built machines but very loud to be around for an extended time. The Schouten replaced it. Don't know how or why but its much quieter.
Thanks all for your comments. I think the main problem we have is due to ground conditions on the cut and collect site we need something real beefy. I’d be interested in the omarv due to the m3 and noted on cutting width. I need to get some demos in and will let you know, need to stream line current process as we’re asked to cut and remove arisings on all sorts of land (current method tractor flail and rake with excavator).
