Considering one of these for hedges and property maintenance work. Quite old at 2003. Best avoided, or OK if cheap and gone through with a fine tooth comb?
Same machine as hinowa or oil and steel as far as I know. Far simpler than today's machines but avoid if the plc is in any way damaged as they are no longer available. Also, not sure if it applies in uk but the single wall 1/4 inch hoses are also hard got now.
Fantastic little machines when they work. Deathtrap if they aren't used and maintained correctly.
Given you seem to know you're stuff I'd say it's a potential bargain.
