Hi
am building an outdoor kitchen / summerhouse ( although it will be used in winter as well )
will be heated with a wood burner
Want to avoid condensation from metal roof sheets
What’s best and economical ?
plain sheets then insulate
anticondensation sheets then insulate
double skin sheets with insulation sandwich
I have seen old box profile on a shed with a thin layer of foam on inside but can’t find it on line is this no longer available ?
any tips
thanks
David
Simple and cheap solution,  cover roof area with a tyvek type membrane, to drain away condensation to outside wall area,  battens on top then a standard uninsulated galvanised or coated corrugated top layer to weatherproof. Works great in my workshop with no dripping.
