Treequips equation was right he just put the wrong m3 ;)
475mm dia / 2 = 237.5mm (0.2375m) radius
[0.2375m radius x 0.2375m radius] x 3.14 π (short Pi) x 5m length = 0.885577m3 volume
using longer Pi its ~0.8863839285714279m3
whats the squared buttom on a cal look like
as per treequip says.
or use windows PC calc (calc.exe) in scientific view
the x^2 button
i.e. input 0.2375 then hit the x^2 button to give 0.05640625 (same as 0.2375 x 0.2375 = 0.05640625)
the x^2 button
sorry but where is the 0.2375 coming out of
SEE below, You have given two diameters (450mm & 500mm) the average of both is 475mm, you use radius which is half of the diameter (237.5mm) expressed in meters i.e. 0.2375m
how do i work the the m3 of a tree trunk its 5 m long by 500 mm dia at one end and 450 mm at the other
can some on tell me hoe to work it out cheers
cheers gibby
use 475mm dia ;)
or ~0.8863839285714279m3
500mm dia = ~0.9821428571428563m3
450mm dia = ~0.7955357142857136m3
Edited by b101uk
Take the average diameter and half it to get the radius. (If it’s under a meter put a decimal point in front of it to keep the result in meters rather than centimetres eg .45)
Multiply the radius by itself (squared)
Multiply that by 3.14 to get the area
Multiply that by the length to get the volume.
