3 hours ago, Joe Newton said:
The Chicane is also way better than the wrench with a hitch due to not adding as much friction.
Can't go wrong with a VT really. The knut is a great hitch but will always bind up at some point
That’s why I’m keen to try it again, before I often found the RW added too much friction, and made limb walks etc more of a faff. Might get some 10mm cord at the same time and have a play, I used to use 8mm cord when I had a vt on my main line which worked amazingly well in the dry but bound very tight when it got wet
