A photo of the door open would help. The first thing I'd try would be a very small bit of plastic or alloy beading stuck above at a shallow angle and covering the door and then a few inches. It's most likely just rain running down the side panels and then into the crack between the door and the body.
Β
A piece of beading on the floor just inside the door might also have the same effect of keeping the runoff out of the compartment.
Edited by doobin
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
