Does anyone know if you can get a chainsaw bar for a Dunn vm420 from anywhere apart from the dealers?
Is it a standard part / fitment?
Runs 404 1.6mm
I've seen Oregon bar mount diagrams, or Sugi and GB have them. I'm assuming it has a slot for studs, pin for tensioner and oil hole on the side like chainsaw bars? Be a case of measure the slot width first - 8/9/14mm etc
None seem to go anywhere near large enough on the slots and have an open back.
Open ended slot is 16mm.
But I did find some numbers on it:-
U(MIGHT BE A W)711-56DUUN
3932
