Just wondering if other people's machines had these double ended screw in pins fitted to their machines at all? 2 of mine have been changed for what looks like a big nut and bolt / bodged....!
One of the correct ones snapped today 😞 was going to remove this one but it's going to foul the frame on the way out! (Snapped one looks like an animal with Stilsons have been at it 😆)
Crap design but just wondering If those are rhe correct pins / bolt etc or if they've moved onto something else.
Cheers
  • 3 weeks later...
I've replaced two. I wouldn't go down the bodged route, just order new from predator. About £25 each.
From memory you can disconnect the rams from both sides and the machine has more swivel so you can remove the bolts.
The advice I got from predator was it happens from a too quick a slew speed. You want a full range of movement to take 8 seconds.
Happy days! Thought this thread was on the bottom of the ocean 😆
Yeah I'm going to have to order some proper ones..... don't know why but the ones that screw upwards seem to have a bloody nut ontop of them! And this is covered by the big plate the engine sits on.
I will have a good look at it next week and get it all sorted.
Cheers Richy 👍
Chris
