Yes I know its a bit late in the season,but do you use the 'winter setting' for the carb intake on your saws,if so does it improve the running of the saw?The manual says it is for below +10 celcius,to prevent carb icing.:001_smile:
Turned ours over on the 200's two weeks before xmas when we got the first lot of snow.
You'll know when to do it when they won't idle without cutting out.
In practice, I find it needs to be more like less than +5C all day to need changing over.
