Hi all, just wanted to get some opinions on whether I can change the round green teeth on my Bandit sg40 to multi tips like on the predator grinders ?
I find the multi tips so much easier to sharpen and maintain.
Any advice would be appreciated. Thanks, James.
You'd have to see if they make a wheel for your grinder. Not sure if you can fund out online? Alternatively you can get a rhino wheel and look at rhino teeth. Rhino teeth also work with the std predator wheel and keepers etc
You would be better getting the Revolution wheel, far better than Green Teethand Multi tip in my opinion (I have had both) they are pretty bomb proof, easy to sharpen and can be retro fitted onto an SG40 as I have one on mine. IMG_1653634044.601615.jpg
