Hi,
been having a bit of a problem with this one.  Rollers wont go forward.  they go back when I press the back button but nothing going forward.  Ive fitted a new speed sensor, new speed switch.  the reverse switch imuminates when it reverses.  fitted new switch on forward valve, but nothing.  checked relays.  joined the wires on the stop bar sensor to make sure there is continuity.  checked belts are tight. nothing. it does work by manually pressing the valve in.
Any ideas or a good person who could fix it. Lincolnshire
Steveeasy
Hi Steveeasy, give us a call at Green Plant UK on 01483 235111. we have qualified Timberwolf technicians who will help you, and we are the UKs No1 Timberwolf parts supplier if you require anything. I can also put you in touch with someone nearer to you if you need hands on help. Gareth of Green Plant.
Gareth,
Thanks for the advice on the phone the other day.  You mentioned stop switch on top.  thought about it,  crossed the terminals on switch and rollers work fine both forward and reverse.  three months ive been trying to get something from it, hey presto.   So I would think a new switch might be needed. going to check the wiring first though to see if its wired correctly.
Many Thanks
steveeasy
