11 hours ago, Jon@CareFell said:
I have had a pair of Andrew’s do the same, an otherwise perfectly good boot. IMG_1638514787.902386.jpg
I had my Andrews (same model) repaired under warranty through H'bros.
Then came Covid and Brexit so it was impossible to collect them.
I finally collected them in August after 18 months.
New sole unit fitted at no cost or quibble.
Great service from Andrews and H'Bros.
   Stuart
Update on the boots!! Today I put them throw a waterproof test of my own that included filling a tub with water and leaving them soak up for around 10/15 minutes then removing them out the tub and going for a walk for around 30 minutes on uneven ground, came back home and really dry socks. So the damp toes must be from sweat build up as it’s been a bit cold and working in snow then a 50 minute drive home with heaters in van really hot on floor area so sweat must of been sweat. Oh well hope they last at least 2 years :)
All my membrane boots get a humidity build up which makes itself known on cold days.
I've normally 3 pairs on the go, a small price for warm dry feet.
It is wet in Brittany.
Wearing in rotation gives them time to dry out.
I've also a pair of Andrews boots without a membrane I use in Summer. Much cooler in the heat but not waterproof even walking through dew.
   Stuart
