Hi all,
Has anyone had any experience reducing the crown of a Swamp Cypress?
I looked at one on a job the other day which has been reduced in the past, around 4-5 years ago going by the re-growth.
Very little to no growth points where the old cuts are, it will almost be a bit of a pollard if I follow the old line.
Do you think it will respond ok to this or should I be taking less off and go back to growth points?
Thanks in advance!
Whilst, generally, "less is more", i.e. BS3998 (but the customer often won't agree) it's reasonable to assume it will tolerate a repeat performance, i.e. "a bit of a pollard" as you describe.
Being deciduous, generally late Spring / early Summer would be best time to prune, and/or phase the work, if you have any concerns perhaps (obviously need the client 'on board' for this as extra time / costs involved.)
Such a shame to reduce a SC but if it's been done before then the way is paved.
ATB
Paul
