makita dcs 6400
petefran
That's not a 6400 cylinder. The carb inlet is a circle hole on them. The bolt on plastic block which you have there, and the inlet shape is the same as what was used on the older dcs6000 and dcs6800.
45mm piston is also wrong. 6400/6401 is 47mm... DCS6000 is 46mm
Piston is toast, but is the cylinder Ok??
Edited by DCS6800i
