Hi
Looking for some advice on killing ivy. I've always cut ivy away at the base of the tree, causing it to die above, and then fall off over time. However, the ivy is still in the ground and can always come back... So my question is, what's the best method of completely removing it to stop it re growing?
Pretty easy to dig up  and clear as shallow roots but need to return and do it several times etc if it really well established and not pratical to do manually for a larger area....
Edited by Stere
