Chainsaw exhaust leaking
echoechoecho
If mating faces are flat and clean (check both with a straight edge, make sure you can't see any light between the two) and gasket is in good condition (you're not meant to re-use gaskets really but 99% of people do) gently try the mounting bolts in the holes to make sure they're not bottoming out before the exhaust is being clamped sufficiently tight. I had this on an old concrete saw that had been in bits, screws had got mixed up and the screws holding the exhaust on were a few mm too long so held the muffler on just about but weren't clamping it to the cylinder at all.
This was my thought .
Thanks, I'll take a look in the morning.
Update.
There was a little bit of swarf at the bottom of one the holes, probably picked up from my bench when I initially removed the muffler.
While it's off I'm going to replace the gasket as its indented.
Anyone know of a cheap supplier of exhaust gasket sheets? I imagine it'll be less expensive to cut out my own than buy a ready-made gasket.
