Evening all, have a husky 346xp and when running the std 15 inch bar have previously used 21LPX chain with no real issues. having used up my stock of half a dozen chains  , I went to order again and now get a few more alternatives , inc 73EXL, 20LPX and type 95. I’m not a pro, but fell and process stuff for firewood for home. Do I stick with type 21 or try something else?
cheers
pixie
Stick to chains of type 21 else you will be wrong pitch or gauge for your bar, although I guess if you've used 6 chains you are probably due a new bar and sprocket as well.
Personally I'd look at the 21BPX as semi chisel is more forgiving on the sharpening.
Dan is spot on, stick to the code 21. This is a .325 pitch with a 1.5mm gauge. Lpx means that it is a full chisel. You could use a Husqvarna H25 which is the same pitch and gauge but a semi chisel.
As you have s 15" bar you will need a chain with 64 drive links, 21lpx064e, 21bpx064e etc.
Many thanks , I have replaced the sprocket and bar about two chains ago, checking it,  it’s just about ok for another chain. I think I will try BPX semi chisel and see how much easier it is to sharpen. I often question my sharpening, especially if I’ve caught something with the chain and have a lot of filing to recover the edge.
thanks again - always helpful on this forum!
pixie
