On 21/06/2021 at 20:24, Fredward said:
I guess if the springs are the only thing changing the position I should probably start with replacing those. Maybe they aren't in as good shape as I originally thought.
I'd start with the springs. That spring in the photo isn't compressed equally. Some turns on the spring are closer than others which is usually a sign that something's off
  • 4 years later...
Did this get solved?
I’m having the same issue. Occasionally a small drop of the saw will cause the intake pipe/boot to pull away from the carb.
I have replaced all springs but I’m unsure if there isn’t something else I’m missing as there is a fair bit of play at the rear of the saw.
It’s hard with no other saw to reference from.
