Sign in to follow this
Chainsaw will
Chainsaw ht km pole pruner attachment problems
Hi I have been using a sthil hl 100 pole pruner and a hl 92 pole pruner with the chainsaw attachment I am having a lot of trouble with them not pumping oil I cleaned out the pump with air but still not working would anyone be able to solve my problem it’s a on going problem I have 3 attachments and they are all giving the same trouble now
Thanks
Share this post
Link to post
I've had similar problems with Kombi attachments. Usually it's been as a result of dirt getting into the system. I replaced one pump myself, and had the second one done by dealers, as it's a tad fiddly. I don't know if the dedicated units are similar.
Share this post
Link to post
You need to pull out the pump and clean, it is a small cylindrical affair and pulls out from the bottom. Easy once you have done a number of them!
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
