On 23/03/2021 at 21:22, spudulike said:
No idea on the tank housing, have you pushed the AV annular buffers in fully? On the screw holes -  I would look at the holes they are going in to and measure the depth if blind holes and fit the screws that won't bottom out. You have to make sure that the screws won't bottom out or puncture the material behind the screw which can lead to issues or damage to the saw.
It is possible a numb nuts has fitted the incorrect screws. Some saws have a cylinder base of different thicknesses front to rear - like the 395XP and the longer ones go to the rear as the cylinder base is thicker to the rear of the cylinder.
Aye looks like some daftys fitted a screw on bolt wi a washer on to the annular buffer, bought the torq head threaded screw and the retainer for it which is the parts meant for it but still no luck in it screwing in
