Does anyone have any good ideas for how to set up a good attachment for a "4srt" chest harness running the chicane on an original petzl zigzag that lacks that second hole for attaching to chest rig?
I used a little accessory type carabiner that I just clip into the carabiner between the zigzag and the chicane. Also use a 4srt chest harness. Works for me.
Awsome good to here that it works for you! I am a person that wants everything to run exceptionally smooth especially after spending lots and lots of money you want to feel that it was 100% worth it at the end of the climb. I had a thaught about adding a dmm xs bat rigging plate onto the connection point of caribener to zigzag from chicane to have the hole to connect to. Your thoughts??
I don't see that that will make it better. I want the connection to be as close my chest as possible, personally. The bat plate would put more distance between the ZZ and the chesty.
Some time has went buy since i first posted this thread and after trying a few things. I am purchasing tonight that zag with second connection hole for chest rig. I am a picky climber and wants things to work perfect and for me to achieve perfection with this system is to definitly purchase the 2019 zag fixed hole because on "srt" i truly do not want a swivel.
