I think the fuel line seals the tank where it exits so the outside diameter is important but based on the vast majority of Husqvarna saws that do this, a fuel line with the outer diameter of 5.7mm - 6mm will do the job, the latter will be a tight fit but both will work. The inner diameter is likely to be circa 3mm with this size line.
