Hi,
I am sorry this isn't about a chainsaw but I have had such great help on here in the past I think it's still the best place to ask.
I have a Husqvarna 122HD60 hedge trimmer.
It didnt run so well so was servicing it - cleaned out carb, reset L and H etc...
I also cleaned the air filter. it's a sponge one so I washed it very thoroughly and left it to dry on a radiator for 2 / 3 days. It was bone dry when I put it back on.
It pretty much fixed it but while I was doing it I noticed that with the air filter off it ran better than with the air filter on. Noticeably faster and more easy revving.
Is the air filter no good and need a new one? or is the answer - of course it runs better with the filter off what did you expect?
I am wondering what to do.
Cheers,
If the engine runs better without the air filter fitter then with it suggests the engine is running a little on the lean side, start by opening the L jet by 1/8th anti clockwise from the current setting.
Not sure I get the thought process......the air filter will make the engine run a little richer as the filter acts like a partial choke, a very dirty one is like having the choke half on .
If you remove the air filter - the revs of the machine, when flat out, will normally rise a bit.
The better performance may just be down to getting a bit more flow in to the engine but if anything, it shows the machine is running a bit rich and taking off the air filter leans it down and this improves it.
Tuning the carb to the engine state is a good idea but it may just be carbon in the exhaust port, a coked up muffler or blocked spark arrester if fitted.
7 hours ago, CEE said:
Hi,
Cheers,
If its just a sponge filter then get a new one and see how that is .
