Still searching for my mewp.
How useful is a jib on a mewp? I've never used a machine without one and use it a lot when positioning in the past, but am considering a Teupen 23gt. It doesn't have a jib at the end and wondering how much difference that makes to getting past a branch into the tree for example deadwooding? For crown reduction I'm sure it wouldn't make so much difference..
The Teupen has a few extra metres height and a couple of meters better outreach, but no jib.
Thoughts?
Thanks.
4 minutes ago, William Clifford said:
I've heard that said before. Wouldn't a decent independent business (got a couple in mind) be able to smooth over the service agent downfalls. Or is it that they'd struggle to get the parts etc from them?
I think you have to go through them for parts - there is quite a lot of machine-specific bits on them.
If buying new you should be ok - I’d steer well clear of second hand though personally, it’s a potentially very expensive minefield with no option to shop around.
