thats a shame, its located at Stoke On Trent, - would imagine way over the 50 miles? will definately bear you in mind if nearer - thanks for contact - is this for a Drax Power Station type burner? - do you chip first? all good contact info for future use - cheers
logbaron
googlemaps says 55 miles so just on the very limits as it is virtually motorway all the way. The burner is much more efficient then a drax burner but the generation works on a similar basis to Drax but is dedicated wood fired not co-fired. We chip using a MBTrac and Heizohack chipper on site into IBC containers. Two containers located behind MB Trac cab.
  • Replies 21
