I’ve a GreenMech 160 Quad Chip Mk1 2010 with 520hrs. It will crank over but intermittently won’t fire up. When it does it works perfect. The mechanics at Balmers (Wakefield) have tried and still failed. “Alt” comes up on the display but it’s not an alternator problem. We’ve checked fuel filter and solenoid etc but still no joy. I’ve checked all “visible “ fuses and the female components and seems ok. PLEASE HELP [emoji1374][emoji1374]
The numbers on the display when cranking get between 130-170 max if that helps any. Also I’ve unplugged the two yellow wires into the starter motor and when I try to start I hear a click (not a flutter) noise which apparently is good news on that score.
