Heavy Duty Log Lifting Tongs
Billhook
On 25/10/2020 at 07:45, Johnpl315 said:
Never used any but there are also these ones which look sturdy enough.
WWW.CLARKFOREST.COM
Bahco 1434 Tractor Tongs for gripping up to 700mm diametre...
They look identical to the Stihl ones I lost, apart from the colour,  but since the ebay ones are twice as wide in jaw spacing,  I think that they may be better
Well they arrived today and I have to say I am very impressed.  There were two large lumps of Sycamore, the first was awkward having many cut off branches and the second was very heavy, making all of the red overload lights come on in the Teleporter which is rated at  2,7 tons with the boom in but the boom was about halfway out so it may well have been near the 1500kg capacity of the tongs.  It was about on the 1300mm limit of the jaws also
With the previous set of Stihl tongs I often had to go and hammer the spikes into the log but I could just drop these ones over and it gripped first time every time.  No trouble to knock off sideways either and an additional feature was the 360 degree swivel which makes manoeuvring the log easy when lowering to position it for the Lucas Mill.
It came to £128 plus VAT which was less than I thought and about the same price as the Stihl ones.
Just bought these scales.  Always wanted to know the weight of logs, one ton boxes full of different split wood varieties, and the weight of the same box full of branch loggings.  They can weigh things up to two tons and are accurate to one kg
i thought that we might have a lockdown competition to see if you can guess the weights of those logs above
The largest sycamore has been down for over a year
It is 32 inches at one end and 33 inches at the other and 147 inches long
The shorter one is 26 inches x 120 inches
The Ash log is 15 inches x 90 inches
Perhaps Steve can think of a prize for the winner
